Outlook Plugin error
UnDutchable30
I am using a pro version and Office 365. I downloaded the 3cx installer via the webclient on a fresh computer, but I got the 3CX plugin error. I have the latest vsto version installed? Can't find any information in the forum for a solution.
Anybody?
API has been deprecated by Microsoft. New API is fully supported server side in v16. So please configure it server side - in v16 even the lowest cost Office 365 is enough and you have it configured for all users...
Hi Nick,
Thanks. Do you mean I have to upgrade to v16 and reinstall the software?
I prefer not to run a beta version in my production environment so everytime I must click the error message away?
I think v15.5 also has it to be honest but its much better in v16....If you are running linux there is no need to re-install but you are right its better to wait for the release version.. Its not that long off if you can wait a little bit it would be great
Reactions: UnDutchable30
aatroxadrian
