PA Speaker solution
Alphabetic
3CX MVP
Hi All,
I'm looking for a solution for a PA - Scenario is for a shop, only 1 speaker required.
So far I've found the Fanvil speaker - Are there are any other solutions available anyone can recommend?
I'd like to know what there is to offer price range wise.
TIA
There's the Fanvil PA2 and if you want complete speaker units the Fanvil iW30, and Grandstream GSC3505/GSC3510 you can check pricing on those models
Ah those Grandstreams are cheaper than the Fanvil which is a bonus, thanks.
Do you know if they work over STUN?
Finatra.us
