Panasonic DECT - KX-TDA0156 base
pitrickzul
Platinum Partner
Hey guys,
I have a potential client that has this base unit KX-TDA0156 currently connected to his KX-TDE200 system we are wanting to replace. Trying to keep the initial cost low so i tought of reusing this base with his current portable devices and change them out at a later time.
After looking over the internet, this seems to be proprietary, am i wrong? Or is there a way to install an ATA to make it work?
No way it proprietary solution
I'm also Panasonic certified.
Br
Br
Thank you for this info. So if a comptetitor says he can make it work with this Digium solution, he's bluffing?
Yes of course. I want to see that working
The only Panasonic dect solution who is working with 3CX is the KXUDS. With the kx udt handsets.
Those are dect multi cell and the base is sip, so you can register users in the same way as Snom solution ( without the complete provisioning feature)
As far as I can see the KX-TDA 0156 is not SIP-compliant.
You can't use it with any SIP server.
3K8iMGWviZ
