Party Time : 3CX, MS SSO and DUO MOBILE
Don Dargel
I am having an issue trying to integrate MS SSO with DUO MFA used during the MS SSO. I have integrated MS SSO and tested it.
Login looks like this...
1. 3CX LOGIN PAGE
2. CLICK ON MICROSOFT LINK
3. LOGIN TO MICROSOFT
4. DUO THEN PROMPTS
5. PUSH WORKS TO DEVICE FOR DUO
6. CLICK ON ALLOW IN DUO
7. 3CX LOGIN PAGE APPEARS AGAIN WITH NO LOGIN.
Has anyone ever received this problem?
@Don Dargel if you use an account without the DUO enabled, only with simple SSO do you have any issues ?
Also is your PBX on the latest stable one which is U8A ?
Make sure also that SSO is enabled on the extension that you try.
KylieWilderman
