Patton 8 port gateway
Mark Jones
Forum User
Intermediate Cert.
I have an 8 port gateway and need to install it, but 3cx only has 4 port how can this be done?
Patton often has templates if you contact them directly.
Mark, really easy to write you own - simply download it from the console of 3CX and just add the additonal extensions. See my attached 16 port as an example.
Is this a Trinity based device or Smartware ?
If you need any assistance let me know.
smartware Patton sn4118 and thanks!
Yeah so if Patton have not responded that template should work regardless, as long as there are more ports. Try it and see, if it won't load we can reduce the ports for you.
it worked thanks!
Reactions: eddv123
[email protected].
