Permanent Disable RECORDING
Anyingisye Maseta
I have 3CX Professional License, how do I permanently disable it so that users should not see that icon in their clients? or at least be gray?
Hello @Anyingisye Maseta,
In the 3CX Professional License, you can only enable or disable the "Call Recording" option. Navigate to Admin > Users > select the users you want > Edit > Options.
The option to "Can start and stop recordings" is enabled by default in Professional Licenses and cannot be changed.
This feature is only available in the Enterprise edition.
Okay thanks. It means i should get ENT license,
Is it possible to top up remained amount and upgrade existing Professional License to Enterprise License?
Yes you can upgrade from the Customer Portal or via a partner (recommended.)
You'll only pay the prorated difference between the two license levels.
Reactions: DimitrisL_3CX
For pricing, it is best to contact your partner, as I can see you already have, or you can fill up our Contact Form.
x1515
