permanent forward
bashrael
Forum User
I have the following situation.
A reception desk that receives a couple of incoming numbers.
At the end of each day (no 'fixed' end) they need to forward these numbers to a group.
The group being forwarded to is different each day..5 of them in total.
We would like to create some speed dials on the reception desk that can enable a forward to these groups.
This would need to be a 'permanent' forward since there will be no one to pick up and forward the incoming calls.
Any ideas on how to do this?
thanks!
no one?
So there is no way to manually forward your incoming calls to another extension?
You can program Available, Away, DoNotDisturb and 2 custom statuses to forward to different extensions or ring groups.
Yes I thought about that but then I cannot use those statuses for the extension itself.
Seems odd to me a simple thing as setting up a 'temporary permanent' forward forward is not available.
aatroxadrian
