Persistent Hot Desk Login Buttons for Yealink T48G Phones?
JCLloyd
Forum User
I set up some phones to be Hot Desk phones, which is not necessary for my office environment, but I wanted the practice... Everything set up well, except...
I want a persistent and reasonable login button for multiple users. I set up some BLFs on the phone web site and quickly found that they are cleared when I log a user off. The only programmable keys I have available (marked as N/A) don't make sense to use... Cancel, HOLD, MUTE, TRAN, Redial, Message.
I will keep looking around, but if one can point me in the correct direction, I'd be most appreciative!
Reactions: jbeckus
To use hotdesking you have to use 3cx standard templates for the phones.
This stops you changing the keys on the phone directly ,as they will be overwritten by the provisioning of the phone due to the hotdesk function
All blf keys have to be programmed via 3cx management console
Note : hotdesking does not support custom templates
Saqqara, thank you for the response. I didn't explicitly modify the existing Yealink SIP-T48 template... nothing even close to what is listed here: https://www.3cx.com/docs/custom-ip-phone-templates/ . Unless adding BLFs to a user extension modifies the template, I think I am good.
It would be nice if the HD0000x Hot Desk profile had it's own set on BLF assignments to reload when someone logs off.
Reactions: Clément Rousseau
Hotdesk phones have nothing set like BLF, this is extension logged in who set BLF keys on phone
[email protected].
