Phones for people with bad vision
Matt Scanzano
Platinum Partner
Does anyone know of a phone supported by 3CX that has bigger fonts and buttons, or even has the ability to increase font size on the display? Currently, we have Yealink T41S, but the display is hard to see for a few particular people.
Thank you
I have not seen SIP sets with this design, but there are a number of single (maybe multi) line sets, designed for people with various disabilities, that could be used in conjunction with an ATA.
Reactions: Matt Scanzano
Perhaps look at the Yealink T48S you have a much larger screen (touch screen) and it is color.
Either that or the newer Android T5x series.
Hey, thanks for the response. Unfortunately, I already showed the T58A in comparison and it still wasn't good enough because of the small physical buttons. The fanvil X6 seems to be bigger in terms of buttons, although display wise it doesn't seem too big.
I guess there's no android based phone with the option to increase font size.
We tested about about 6 different phones before landing on the Fanvil x6. One of the reasons we went with it was because employees preferred the larger font size on the screen for incoming calls, when typing a number, and on the BLF labels. The physical buttons and font size are larger as well.
This was in comparision to:
Yealink T42, T46 and T48
Fanvil x4, x5
Htek 926
Attached are display of phone numbers and incoming calls.
View attachment 8229 View attachment 8230
Thank you very much! The pictures really helped!
megalmazan
