Phones Search Bar
Drain Bamaged
Good Day,
In the Phones section of the admin web client, I should be able to type in "Not Supported" in the search bar and see all phones needing a firmware update. Its one of the few things I cannot search for at the moment.
Thanks.
Reactions: sbrammer
If it helps the column headings are clickable to sort, so that will at least group firmware versions together.
Good Day,
Thanks.
I agree.
What i have been doing is doing a search for different models (t29g\T48s\T23g\CP960) to see if they need a firmware upgrade when the phones on the dashboard go from a green check to a red exclamation.
Since this is specific to firmware and most fields are searchable already, perhaps a checkbox or dropdown to toggle between "all phones" and "needs firmware update" or maybe "in warning state." With 10 phones it's kind of meaningless but with a few hundred it would be a convenience.
3K8iMGWviZ
