Solved Poly Studio X30
Clément Rousseau
Titanium Partner
I try to set up a Poly studio X30 as it can use SIP.
SIP set up is easy, I just wrote SIP info, for the extension I want, in GUI of this machine and calls working great, but I can't find a way to use video for theses calls.
Any idea why and what can I try ? Is there a setting in 3CX to allow video ? Is video only working with supported devices ?
regards,
There is not settings for video within 3CX.
Video calls are negotiated between the each endpoints, both devices have to have the same video codex, etc
Hi @Clément Rousseau
No, video is negotiated between endpoints so there is no setting in 3CX that would enable/disable video.
nvm it was only a problem of firewall ports ;)
Reactions: JohnS_3CX
Finatra.us
