Portal not found
Chris Palmer
Webmeeting has been a great alternative to zoom and has also been a great starting point of conversation to sell the system.
However, really embarassing when it doesnt work and continues not to work during a time when we need it the most.
Continually getting 'Portal not found' along with our domain and 3cx .net
Is this a 3cx fault? as we have changed nothing?!?
Hi and thanks for taking the time to reply. No, all good as far as domain and firewall etc. This broke all on its own. I can ping webmeeting-director.3cx.net no problem and our SBC can also get out no problem. Our PBX is cloud based and no outboand ports are blocked.
Same issue here. Worked fine a couple of weeks ago and nothing changed on our side.
Hi Chris
Shall I assume you also restarted the System Service? If so and that didn't help, then go ahead and send me a private message by clicking on my name, and send me your Key and FQDN
Hey John,
When you mean restarting the system service which one is it in this list ? Is is all of them ? Will it disrupt incoming and connected calls ?
It's 3CX Phonesystem 01 System Server
I believe not, because it does not interrupt the SIP Server, Tunnel or Media Server
Thanks John ! That fixed the issue. Not sure what happened in the first place but a least it works now !
Reactions: JohnS_3CX
x1515
