Solved Portal showing machine offline after reinstall
Rob_Craig
Had system failing to upgrade from v16 to v18 in AWS Lightsail so ran reinstall option from portal.
When process ran it installed a new instance in Lightsail. I switched original public IP to new instance but still showing as offline in portal.
Can connect to web interface with no issue and all other functions work.
Below error that shows in portal
To confirm, when you say portal you're referring to the 3CX Portal correct?
First, off make sure that you've shutdown the old machine and enabled the instance manager on the new one under "Settings >> Instance Manager".
Reactions: Rob_Craig
Sorry yes that portal.
Thanks found it and enabled it. It is off by default during the install process?
Also yes shutdown and removed old AWS instance the moment I saw it had created a new one during reinstall process.
Reactions: ChrisC_3CX
Brilliant! Glad to see this has been sorted!
That is the case indeed.
Don't hesitate to start a new thread should anything else pop-up!
Bluebox Global
