Solved PowerShell Users, wrong ext
Simone Rota
Forum User
Powershell generated has this row
Set-CsPhoneNumberAssignment -Identity [email protected] -PhoneNumber "+390524533301;ext=000" -PhoneNumberType DirectRouting
But the extension with this email is the 238 (It was "000" before, a mistake).
I've correct the email in "000" and "238" with correct address, more than 24 hours ago.
But still Generating the script, I've found
Some idea?
Thanks?
Simo
Try deleting Ext "000" from the Management Console, then re-create it. After this, restart ALL 3CX services. Once they come back online, try generating the script again.
Ok, It worked. Thanks
Reactions: NickD_3CX
