Solved Preparations for MSTeams integrations failing.
jpeppas
Hi to all.
I have read through all the guides I could find regarding preparing my self-hosted 3CX PBX. I have successfully connected and synced users and SSO with O365.
However, I am stumped on the certificate issue. My certificate provider has CA as "DigiCert Global Root CA", which is in the "MS include CA Certificate List"
I have added the certificate (provided as a single file from the provider) in both the "Settings->Integration->Microsoft 365 Integration->Teams Direct Routing (Alpha)" setting (and it has recognized the certificate validity and ending date), and also in "Security->Secure Sip"
After this, in order to see if the certificate is installed correctly, I expected to be able access the management console from both the 3cx provided url, and the custom one.
However, when I try this, I get a warning from the browser that the url visited does not match the certificate (the 3CX provided url)
Any ideas what I am doing wrong?
BR,
Jim
The Teams certificate is only used for port 5062 (5061 for custom domains generally).
HTTPS still needs to use the PBX FQDN.
aha.. so I wont know if it's ok until I get the Teams to show the dial pad (and try to call) according to Keith Winhall_3CX in his "Unifying 3CX with Microsoft 365" series..
OK, I'll get back to you as soon as Teams refreshes
Calls are reaching the PBX (I have other problem's but will open a new thread)
Please consider this closed
Reactions: NickD_3CX
No members online now.
RJenkinsROCK
