Print Ext Lists
Jases Brown
Gold Partner
For the life of me, I cannot find where to print an extension list or more importantly a paging group list. Any help would be appreciated. If it is not possible, it would be a nice addition. BTW, I don't have sufficient privileges for posting a new idea.
In the 3CX management console select "Extensions" from the left-hand side-panel. Then select "Export" at the top of the screen.
Thank you. That is functional for extensions, but is there a way to do the list of ring/paging groups? I have a customer that has 40+ paging zones setup. Seems elementary to be able to print lists.
You can get this information using the 3CX Call Control API. Alternatively, we have a REST based API that could get you the information as json, or 3CX table data (again as part of the REST API). I can't think of any other ways to get the information.
Support99
