Unsupported Problem integrating Mediatrix 4102S
dfe-admin
I have tried to integrate a Mediatrix 4102S FXS gateway according to the Using an FXS Mediatrix Gateway with a 3CX IP PBX Server tutorial. Unfortunately, there is already a problem relatively at the beginning.
After I put the integration templates in the necessary place in the file system and refreshed the application, a brand Mediatrix appears according to section 3.2, but the dropdown for model/device remains empty.
:confused:
What am I doing wrong?
As this is a third party solution, you are probably best in contacting Mediatrix directly.
I have tried contacting support there, but so far no response.
I have attached the corresponding XML file here. Maybe someone can take a look at it and find the problem. ;)
Finatra.us
