- Joined
- Nov 26, 2025
- Messages
- 5
- Reaction score
- 0
I recently migrated my 3CX system to a new Lightsail instance running v20. The previous instance was working perfectly, but after moving to the new server and assigning a static public IP, my SIP trunk is no longer working as expected.
Lightsail IPv4 Firewall:
Environment
- 3CX v20
- Hosted on AWS Lightsail
- New instance with static public IP
What works
- SSH access works normally
- Admin Console accessible via
https://PUBLIC_IP:5001 - Web client loads correctly
- Extensions are registered
What doesn’t work
- Incoming calls only ring continuously
- No IVR / waiting music
- Call does not proceed to Digital Receptionist
- Event log shows SIP activity but no proper routing
- TCP 443 (HTTPS)
- TCP 5001 (3CX Admin)
- TCP 5060–5062 (SIP)
- TCP 5090
- UDP 5060
- UDP 5090
- UDP 9000–10999 (RTP)
