- Joined
- Jan 15, 2018
- Messages
- 3
- Reaction score
- 0
Hello everybody,
For local usage we need our FronEnt Web application call CallTriggerCMD.exe to start dialing in 3cx Windows Phone
I've got a problem with calling CallTriggerCMD.exe from Windows service.
.net core Api Self-hosted script has calling standard command line:
C:\ProgramData\3CXPhone for Windows\PhoneApp>CallTriggerCmd.exe -call 231231121
When I'm running application manually this working perfectly and 3cx Windows Phone application is dialing, therefore when I have from Windows Service for example - http://localhost:5555/api/MakeCall/231231121, I'm getting this error:
System.ServiceModel.EndpointNotFoundException: There was no endpoint listening at net.pipe://localhost/CallTriggerService/e6533f87-9ac6-405f-889b-19eedefc814d that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details. ---> System.IO.PipeException: The pipe endpoint 'net.pipe://localhost/CallTriggerService/e6533f87-9ac6-405f-889b-19eedefc814d' could not be found on your local machine.
--- End of inner exception stack trace ---
Server stack trace:
at System.ServiceModel.Channels.PipeConnectionInitiator.GetPipeName(Uri uri, IPipeTransportFactorySettings transportFactorySettings)
at System.ServiceModel.Channels.NamedPipeConnectionPoolRegistry.NamedPipeConnectionPool.GetPoolKey(EndpointAddress address, Uri via)
at System.ServiceModel.Channels.CommunicationPool`2.TakeConnection(EndpointAddress address, Uri via, TimeSpan timeout, TKey& key)
at System.ServiceModel.Channels.ConnectionPoolHelper.EstablishConnection(TimeSpan timeout)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOpenOnce.System.ServiceModel.Channels.ServiceChannel.ICallOnce.Call(ServiceChannel channel, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOnceManager.CallOnce(TimeSpan timeout, CallOnceManager cascade)
at System.ServiceModel.Channels.ServiceChannel.EnsureOpened(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at TCX.CallTriggerCmd.ICallTriggerService.MakeCall(String destination)
at TCX.CallTriggerCmd.Program.<>c__DisplayClass1_0.<Main>b__1(String destination)
at Mon
ptions.Option.Invoke(OptionContext c)
at Mon
ptions.OptionSet.Parse(String argument, OptionContext c)
at Mon
ptions.OptionSet.Parse(IEnumerable`1 arguments)
at TCX.CallTriggerCmd.Program.Main(String[] args)
What I've tried without success:
1) Run 3cx Windows Phone as administrator
2) Run service as the same User as using 3cx Windows Phone
3) I've checked - no other applications or services using the 5555 port
4) Reinstalled 3cx Windows Phone
5) I've checked Net.Pipe Listener Adapter is running(restarted him)
6) I've checked - 3cx has Pro licence
7) I've even reinstalled Windows
I'm really struggling with this problem, anyone could help me?
Server stack trace:
at Mon
at Mon
at Mon
