- Joined
- Sep 8, 2018
- Messages
- 24
- Reaction score
- 2
What should I enter in the User ID field instead? Leave empty?change this for test, in User ID normally this is something alphanumeric and not extension number
What should I enter as User ID? Leave empty?change this for test, in User ID normally this is something alphanumeric and not extension number
Yes, 10 is the extension.is 10 your 3CX extension ?
Did some searching and this might have to do with some special characters I used in the extension names. Will do a change and report back.Yes, 10 is the extension.
Changing the ID as suggested did not help.
I started the logger and checked the log with the SIP analyzer tool. The PAP is trying to connect. This is the message I found (I manually changed some digits to avoid leaking info)
28.01.2020 21:20:56:365 | 10 | Discarded invalid message: REGISTER sip:10.0.0.16 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.11:5060;branch=z9hG6bK-deea2cdc
From: rdr Trdls 1 <sip:[email protected]>;tag=a652082468611dcco0
To: rdr Trdls 1 <sip:[email protected]>
Call-ID: [email protected]
CSeq: 32490 REGISTER
Max-Forwards: 70
Contact: rdr Trdls 1 <sip:[email protected]:5060>;expires=600
User-Agent: Linksys/PAP2T-3.1.15(LS)
Content-Length: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura
Does this help in any way?
Forgot this line:
28.01.2020 21:21:16:364 | 10 | Invalid UTF8 sequence in incoming SIP message: 0xxe7 x64
perhaps letters you used are not encoded in UTF8 and this is not the taste of PAP2.Invalid UTF8 sequence in incoming
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
