Problem with weepee trumk configuration
andreslycke
I try to configure my SIP trunk form weepee but i get always error Registration at Weepee has failed. Destination (sip:35.205.148.73:5060;lr) is not reachable, DNS error resolving FQDN, or service is not available.
In version 18 this works fines. But in version 20 i can´t make this working.
Can someone help me :)
Event Log ID 12293 Failed registration - If this is the only failed entity, then the remote side is probably down. If multiple services are failing, then you might have a network issue.
Make sure you have in the file /etc/resolv.conf only as nameserver 1.1.1.1 and nameserver 8.8.8.8
We also advise you to use supported sip trunks in the system where these will work flawlessly.
If you keep presenting issues with the unsupported voip provider then please contact them so they can assist on it.
Have a great week ahead!
LeeonLau
