Problems after upgrade to Ver 18
tony.grant
I recently upgraded from Ver 15.5 to Ver 18.1. During the upgrade Debian upgraded from Ver 8 to Ver 10. After the install he phone system worked however every 20 minutes all lines on each extension instrument light up and indicate an incoming calls, it stops after placing each line off-hook (answering it) or it stops automatically after each line rings about six times. I have checked everything that I can think of and am hoping someone can help and that it is something simple. I am also wondering if remnants of Version 5 still exists and could be causing the issue. I have placed a small section of the activity log below.
Code:
02/28/2022 7:37:42 AM - There's another STUN server that resolves to the same IP: 54.39.179.240:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
02/28/2022 7:19:31 AM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.14:5066 tid=6e81f2c112c67444 [email protected]:
REGISTER sip:192.168.1.8 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.14:5066;branch=z9hG4bK6e81f2c112c67444
Max-Forwards: 70
Contact: sip:[email protected]:5066;transport=udp;reg-id=4;+sip.instance="<urn:uuid:00000000-0000-1000-8000-000b829e0b6a>"
To: sip:[email protected]
Call-ID: [email protected]
CSeq: 40017 REGISTER
Expires: 3600
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK
Proxy-Authorization: Digest username="10003",realm="3CXPhoneSystem",algorithm=MD5,uri=sip:192.168.1.8,nonce="414d5359621bdcd151:1ebb1b087317949e5d5e2904dafd7ec7",response="57a06075e669f82260ce78a75551d56a"
User-Agent: Grandstream GXW4104 (HW 2.3, Ch:11) 1.4.1.5
Content-Length: 0
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
02/28/2022 7:17:42 AM - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
Tony Grant
Hi @tony.grant,
When you say this, can explain what exactly happens? Are your phones ringing? Where is the phone showing an incoming call, is it a BLF?
Also, I would suggest to remove the FXO and provision as per our guide: https://www.3cx.com/voip-gateways/grandstream-fxo/
I have attached pictures showing one of the phones in the good and problem state. The problem occurs with all phones every 20 minutes. The phone shown has 6 lines, normally when a legitimate call comes in the specific line will flash red. In this case there is no legitimate incoming call, however the phone rings and all lines flash red. If one line is answered it turns green and the others remain flashing red until they are answered or until they time out.
I think I have rectified the authentication failure issue however this has not corrected the problem. Form the activity log below I believe it is connected to the Stun Server.. I have opened all the necessary ports in the firewall. Could it be related to The message about another stun server? I checked the processes running on Debian thinking that there were 2 STUN servers running but I could find any evidence of this.
02/28/2022 11:37:43 PM - There's another STUN server that resolves to the same IP: 54.39.179.240:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
02/28/2022 11:17:43 PM - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
02/28/2022 10:57:43 PM - There's another STUN server that resolves to the same IP: 54.39.179.240:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
02/28/2022 10:37:43 PM - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
02/28/2022 10:17:43 PM - There's another STUN server that resolves to the same IP: 54.39.179.240:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
02/28/2022 9:57:43 PM - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
02/28/2022 9:39:49 PM - [EC100009]: External application [3CXPBX:0/PbxConfigTool] is disconnected:
02/28/2022 9:37:43 PM - There's another STUN server that resolves to the same IP: 54.39.179.240:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
02/28/2022 9:17:43 PM - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
02/28/2022 8:57:43 PM - There's another STUN server that resolves to the same IP: 54.39.179.240:3478/UNKNOWN_TRANSPORT fk=0 tgt=; ignored
gmacinit
