Solved Prompt Playback from external
RafalR
I would like to play audio file from external server. In that case I need to be able to download it first. I already found edossantos's post but it doesn't work for me.
Full C# code I use:
Code:
using System;
using System.Collections.Generic;
using System.IO;
using System.Net;
using System.Net.Http;
using System.Text;
using System.Threading.Tasks;
namespace FileDownloader
  public class FileDownloader
    private async Task downloadFile(string uri, string fileName)
      using (HttpRequestMessage httpRequest = new HttpRequestMessage(HttpMethod.Get, uri))
        using (HttpClient httpClient = new HttpClient())
          using (HttpResponseMessage httpResponse = await httpClient.SendAsync(httpRequest))
            byte[] byteArray = await httpResponse.Content.ReadAsByteArrayAsync();
            using (FileStream stream = File.Open(fileName, FileMode.Create, FileAccess.Write, FileShare.ReadWrite))
                stream.Write(byteArray, 0, byteArray.Length);
        public void DownloadFile(string uri, string fileName)
            downloadFile(uri, fileName).Wait();
CFD component:
There is no error in CFD but in 3CX Management Console in Call Flow Apps section.
I will be grateful for any help.
Remove the namespace from your C# script. Leave just the class.
Thank you. It works fine now.
Reactions: edossantos
youwillbrun
