Solved Provision Snom 720
Alphabetic
3CX MVP
Hi all
i'm trying to provision a snom 720 (8.9.3.88) over an SBC to no avail.
I've put in the URL in to option 66 and i've tried assigning it from the mgmt console but it wont provision.
I am also unable to log in to the GUI as it says the password is wrong despite me using the default 0000 and the one from the ext page.
nvm - password was last 6 characters of MAC
Those are EOL, we no longer test them on modern 3CX systems and they may indeed be unable to provision.
Try disabling option 66 on the network, then factory reset, and see if you can provision it manually or via PnP.
Unfortunately as with all EOL devices, we cannot guarantee they will continue to work..
I've been able to set it up manually.
Reactions: JohnS_3CX
