Provisioning Client Settings for all users
oJo
Is there any way to make the client use certain default values? Our customers rely heavily on using a shortcut to dial and NEED + to be converted to 00. We know that there is a convoluted way to change this in the client software, but we need a reliable way to deploy this to all users. I have experimented with manipulating the settings XML, but it's a terrible ordeal.
oJo, this should be done at the PBX level, via outbound rules; the PBX is the one connected to providers, therefore the one knowing if the provider requires + or 00.
But the client strips the + and just dials 43XXX instead of +43XXX. With the setting changed it dials 0043XXX.
That's what I'm talking about: each 3CX client user can customize its own settings, which is highly unreliable for your purposes. So, in the PBX, define such kind of rules:
  • for every number starting with +, replace + to 00
  • for every number starting with 43 and length of XX, prepend 00
(for every number starting with 00, leave it unchanged)
I'm not a master of PBX configuration, but I guess the two rules above combined will cover your case. Even more, it will cover ALL clients (Windows, Android, iOS, MAC, hard phones). See also the E164 Processing.
This doesn't work for us, as numbers starting with 43 can be local numbers as well. There has to be a way to reliably deploy the 3CX client setting to process + to 00 instead of dropping the +. This is one of the most basic features of dialing any phone number IMHO.
E164 doesn't help?
We are using E164 Processing, but the 3CX Client strips the Plus sign unless the client-side setting is configured.
I understand. So we go back to the outbound rules I mentioned above, where you missed the most significant element of my description:
number starting with 43 AND LENGTH of XX
so, if the number is local, it would be 43000000 (length 8). If it would be international, stripped of +, would be 4343000000, length 10, agree? In this case, your outbound rule will says
- for any number starting with 43 AND length 10 append 00 (so the number will become 004343000000).
Am I wrong?
I don't even think there is a minimum international phone number length, but it still wouldn't solve a local phone number conflict, as those can have virtually any length depending on the internal numbering scheme used by the called company. So if I dialed (+)44 870 990 8881 I'd want to reach the London eye internationally, but (+43 732)448709908881 would technically be a valid local number as well.
It also doesn't solve the issue of wanting to centrally manage the client settings, is there no mechanism to manage the 3CX client at all?
gmacinit
