Provisioning Yealink T48S on STUN using WiFi
alex0317
I've been wanting to provision a phone using WiFi on STUN, however I cannot get it to work. It provisions normally over a wired cable but for some reason it will not register using WiFi adapter. I've tried manually provisioning it and tried multiple WiFi adapters and still have no luck. My 3cx is setup on the cloud. Any suggestions?
Do you have the Yealink OEM Wi-Fi adapter? It won't work with random adapters like D-Link or Linksys.
Yep, I tried using the Yealink WF50 and it won't have service.
We as 3CX don't support IP Phones connecting over WiFi, even for models that we list as "supported".
This is also something that is not tested during our regression tests.
Wow, ok. Would this be implemented in the future?
Probably not. I'm not saying that it won't work, I'm just saying that we as 3CX are unaware of any issues devices may have with WiFi.
I pretty sure that you are probably trying to use WiFi because there isn't an available Ethernet port where you want to place the device, but it may be worth installing a cable as it could save you trouble in the future (Ethernet is much more reliable, plus it's what we test with).
Finatra.us
