Public Folder Contacts in Version 16
ITSteve
Forum User
I would like to sync both my users' contacts and Public folder contacts between Office 365 and 3CX. Just like we did in V15.
I have already upgraded to v16 before I noticed the Public Folder contacts was not part of 'Office 365 Integration'.
Is it possible to use Office 365 Integration for user's contacts and status AND Exchange Contact Synchronization for public folder contacts?
If not, is there any ill effects to disable Office 365 integration and continue to use Exchange Contact Sync?
I turned off 'Office 365 Integration', and continued to use 'Contacts - Exchange'. At the time, I found instructions online, but I can't locate the link at the moment. Here is what I have set up:
12069
12070
I hope they continue this feature in upcoming versions, or add Public Folder selection to Office 365 Integration.
Hi thanks a lot.
I've just setup exchange and I can access to the common contatc list via public folder
Christian
So in v16 I still have access to Public Folders for contact sync? This is the ONLY reason I have not updated to v16.
Yes It seems working well in V16 windows version and fresh install. But I also see a lot of person coming from V15 having issue.
12074
[email protected].
