Push - delete account from APP
paulodagraca
3CX MVP
Platinum Partner
When an person leaves the company and forgets to remove/delete the 3CX account from his smartphone, the account will still be active.
Sure the admin will delete the extension at termination point, but the account is still on the smartphone.
This means the APP will try to connect over and over again, and sometimes trigger a Blacklist, where the smartphne will get another IP on the Cell of WIFI all day long, and the Blacklist just keep on going every day at least one (this happend to me a few times).
The person has left the company, and will not return, where there is no access to the smartphone.
So in my head it would be great to force a DELETE account if the registration was not correct at multiple times (at point of Blacklist?),
It would be nice that the server will not just respond with "error wrong login", but also "Delete your account".
The 3CX APP on the smartphone will than delete the account that did try to login from the list, problem solved.
And if the person is still with the company but just had a non working account..... simple, login to the webclient (recover password if needed), and scan QR again, BOOM done!
Let's keep it clean and safe, it either works or its gone :)
Do you also like this, please Vote this UP, thx.
Upvote 27
