I'm not very good with wireshark, i see no traces of ipv6.Please check the NIC via command line and make sure the inet6 is not assigning any IPv6 address.
Then you can start a packet capture in the pbx, replicate the issue, validate that DNS is working properly and filter the capture to the IPs used to connect with the PUSH services.
There you can see if there are any reset connections, and packets that are not getting any response.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
