Solved PWA-Webclient: No starting with Windows login.
timmbo
I installed the PWA-Version of the Webclient and i activated the "Starting with Windows login", but it won't start.
I use Windows10 and i installed it with the Edge Browser.
I see at the Taskbar the Icon, but i must click on it to get started.
Bye
Timm
Hi Timm,
I just tested this on Edge 97.0.1072.76 and when I installed I made sure to check this option:
With these options though, after a reboot the PWA app re-appeared again.
Did you do this?
Is there something that could be controlling the startup applications?
Hi, yes i did that."Auto-start on device login".
Bye
Timm
I have found that this option may be affecting the launch on OS login:
Hi Nick
This was set to on.
I rinstalled the App and let's see on the next Boot-up what's happening.
Bye
Timm
today it worked like it should.
But somebody changed something, because this time i'll get 4 checkboxes.
Bye
Timm
Good to hear it worked!
Not sure what could have changed with a re-install however.
I'll set this as 'Solved'.
Roman Mazur
