Quick Fix for Outbound Dialing Issue 3cx V20
The Telephony Co
Gold Partner
Issue with inbound calls coming in, while outbound calls are not going through. To resolve this quickly, please follow the steps below:
  1. Configure SIP Trunk in Generic Mode:
    • Set up the SIP trunk similar to how we did in version 18.
    • Route calls to the desired extension or queue.
  2. Test Incoming Calls:
    • After configuring the SIP trunk, test the incoming calls to ensure they are working correctly.
  3. Export XML File for Outbound Calls:
    • Navigate to the "Voice and Chat" option.
    • Click on the three dots at the end.
    • Select "Export File" and open the exported XML file in Notepad.
    • Locate the "Parameter Out" line and set the parameter for outbound calls.
    • Save the file.
  4. Import XML File:
    • In the "Voice and Chat" option, click on the three dots again.
    • Select "Import Provider."
    • Choose the previously saved XML file to import.
By following these steps, the outbound dialing issue should be resolved.
This must be specific to you?
I dont see any reason why creating a generic SIP trunk in v20 wouldnt work.
have you compared the 2 XML files from v18 and v20?
Did you previously set up an unsupported SIP Provider using a supported SIP provider template?
Reactions: bitn2
ARKC
