Raspberry Pi DPKG error
SRees
Hi All,
Im trying to install 3cx on my raspberry pi. I have done this previously and have had no issues.
For the last 3 days I have had this as my main issue
Code:
dpkg-deb (subprocess): decompressing archive member: lzma error: compressed data is corrupt
dpkg-deb: error: <decompress> subprocess returned error exit status 2
dpkg: error processing archive /tmp/apt-dpkg-install-ZsxFfN/70-3cxpbx_18.0.2.314_armhf.deb (--unpack):
 cannot copy extracted data for './usr/lib/3cxpbx/System.Private.DataContractSerialization.dll' to '/usr/lib/3cxpbx/System.Private.DataContractSerialization.dll                   .
.dpkg-new': unexpected end of file or stream
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I had originally tired to install this on bullseye (new raspberian / debian) but found it didnt work so went back to buster.
but keep getting the same error any ideas ?
Reactions: ChrisC_3CX
May have found the issue its a pi b+
Last one I did was a 3 b+
this pi may be too old
But yes I did use the guide above. Like I said I have set this up before but had no issues.
Have tired with the image above as well as the image direct from raspberrypi.com same results
have also tired 2 different SD cards one being brand new
The Pi b+ is old indeed and probably the reason you're having the issue. We actually recommend the Pi 4(B4 or B8), but, in light of the hardware shortage, you could potentially try using a Pi 3B+ if you have one instead.
Silent_Guru
