Solved Raspbian sbc issue
NetSolution
Issue with 3cx sbc on raspberry pi 4 canakit on the same network and subnet as the windows SBC and IP phone to provision. With Raspbian sbc the IP phone will not register or provision. With the window SBC the IP phone with register and provision fine. when using the raspbian sbc I take the windows sbc off the network complete so the is not issues.
I have formatted the raspberry pi 4 a few times and installed the SBC from 3cx and the result are still the same for ip phones to not register nor provision.
Any insight would be greatly appreciated.
User: ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL=http://www.raspbian.org/RaspbianBugs
user:~ $ sudo service 3cxsbc status
● 3cxsbc.service - 3CX Session Border Controller
Loaded: loaded (/lib/systemd/system/3cxsbc.service; enabled; vendor preset: e
Active: active (running) since Mon 2021-07-05 20:05:57 EDT; 1 day 18h ago
Main PID: 2927 (3cxsbc)
Tasks: 5 (limit: 4915)
CGroup: /system.slice/3cxsbc.service
├─2927 /usr/sbin/3cxsbc -m /etc/3cxsbc.conf
└─2944 /usr/sbin/3cxsbc -c /etc/3cxsbc.conf
Jul 05 20:05:58 raspberrypi 3cxsbc[2927]: NOTICE | 20210705-200558.136 | | SBC
Jul 05 20:05:58 raspberrypi 3cxsbc[2927]: Full app pathname: /usr/sbin/3cxsbc
Jul 05 20:05:58 raspberrypi 3cxsbc[2927]: Application path: /usr/sbin/
Jul 05 20:05:58 raspberrypi 3cxsbc[2927]: ** Section: [General]
Jul 05 20:05:58 raspberrypi 3cxsbc[2927]: ** Section: [Log]
Jul 05 20:05:58 raspberrypi 3cxsbc[2927]: ** Section: [Bridge/123456]
Jul 05 20:05:58 raspberrypi 3cxsbc[2927]: Writing logs to: /var/log/3cxsbc/3cxsb
user:~ $ sudo netstat | grep 5090
tcp 0 0 raspberrypi:33973 ip.ip.ip.ip.bc.:5090 ESTABLISHED
udp 0 0 raspberrypi:51746 ip.ip.ip.ip.bc.:5090 ESTABLISHED
user:~ $ netstat -gn
IPv6/IPv4 Group Memberships
Interface RefCnt Group
lo 1 224.0.0.1
eth0 1 224.0.1.75
eth0 3 224.0.0.251
eth0 1 224.0.0.1
lo 1 ff02::1
lo 1 ff01::1
eth0 1 ff02::fb
eth0 1 ff02::1:ff18:4ebe
eth0 1 ff02::1
eth0 1 ff01::1
with Raspbian SBC system it will be up and running to the 3cx PBX and the phone will NOT register & provision:
Statistics
StatusUP
Uptime32 min
Build Version16.2.24
Agents Behind SBC1
Calls Behind SBC0
TCP EncryptedYes
TCP Packets Received/Sent39817/25398
UDP StatusUP
UDP EncryptedYes
UDP Packets Received/Sent40410/40427
UDP Ping47 ms
Operating SystemRaspbian
System CPU Usage6.34 %
System Memory Usage6.11 %
SBC Memory Usage0.09 %
Disk Usage7.05 %
Bandwidth Used From PBX (Rx)40.2 kB
Bandwidth Used To PBX (Tx)8 bytes
RTP Packets Received/Lost from SBC0 / 0 (0 %)
RTP Packets Received/Lost from PBX0 / 0 (0 %)
If I reinstall the windows SBC system it will be up and running to the 3cx PBX and the phone will register & provision fine:
Statistics
StatusUP
Uptime0 min
Agents Behind SBC1
Calls Behind SBC0
TCP EncryptedYes
TCP Packets Received/Sent25/23
UDP StatusUP
UDP EncryptedYes
UDP Packets Received/Sent6/8
UDP Ping45 ms
Operating SystemWindows
System CPU Usage19.68 %
System Memory Usage42.75 %
SBC Memory Usage0.08 %
Disk Usage48.70 %
Bandwidth Used From PBX (Rx)2 bytes
Are you using the same IP address on the LAN for both the windows and Pi SBC?
I think in that scenario it would just work seamlessly.
However if the Pi has a different LAN IP, then you must go to the extension, Phone Provisioning, make sure it's set to SBC mode and set the IP address for the SBC.
This is a per phone setting.
Then re-provision the phones.
I assuming you are auto provisioning the phones and not manually?
Reactions: JohnS_3CX
Thanks. I over looked something simple...With out your pointing it out id still bang my head.
Thanks you very much
Finatra.us
