Recommended CDR Reporting solutions
mdkberry1
I hope this is the right forum to address this question.
I am looking for a CDR solution that would integrate with Elastix to provide
1. Automically emailed reports on a daily/weekly schedule
2. reports grouped by selected extensions (so that managers can receive reports on their staff members phones only)
3. summary reports e.g. time spent on calls, calls made over 1 minute duration, unique dialed numbers etc....
If anyone can point me in the direction of solutions for the above it would be appreciated
Rgds
Mark
well so far the options have a been a little disappointing, CDR reporting software seems pretty lacking in this area, at least for what my clients needs are. My research has revealed the following, feel free to correct any observations if they are wrong...
CDR-stats - looks good but doesnt appear to satisfy points 1,2 or 3 listed in my original post, also it will need installing to its own server as it wont install to Centos 5. Not a big deal but something to note.
Asternic CDR reports - great if you want Call Centre inbound reports but I can find virtually nothing on the CDR reports version other than a little info, certainly no screenshots. After further searching it seems the CDR version is free, but not exactly much more than the current CDR version used on Elastix. Again it doesnt satisfy points 1,2 or 3 in my original post.
Queuemetrics - Call Centre stats, not what I need.
SamReports - I really want to like this one as it looks good, but after going through the screenshots I am quite confused by the layout. It looks like fancy pivot tables. again not sure this can satisfy points 1,2 or 3.
Thats about it in the offerings for CDR reporting, so next I looked at alternatives.
it seems the CDR records in asterisk are stored in a Master.csv file , so I pulled a copy out and realised its propbably just as easy to learn how to use pivot tables in Excel and figure out your own stats. So I am looking at that as a temporary option just to get bespoke reporting that I need.
But there is one other solution and this may end up being the way forward once I get it tested, but using a combination of 'tail -f' command and 'netcat' I think I can pipe live, real-time call records being written to the Master.csv file out to a TCP port, this then opens up access to other professional CDR reporting software, which is likely to be the way my client goes. I have to find out if the info being streamed is actually usable by professional CDR software in its raw format but one company I spoke to thought it would be so long as I could get the TCP stream going on they can adjust the rest for a fee.
Hope this helps anyone coming by here looking for CDR reporting. I am surprised there isnt something better available that can cover the points I listed in the original post. I would love to see someone challenge that and prove me wrong.
there was yet one more solution and that was the best -
make your own, or better still get someone else to code it for you.
I should have version 1 completed within a few weeks
Look forward to seeing results. Let us know how it goes.
the results are in.
I ended up getting it developed professionally, called CDRPlus , you can see screen shots on www.clarilite.com just follow the links.
it is in two modules at the moment running in Windows environment too but reaches into the PBX and pulls from the asteriskcdrdb.
one modile does a live call display from a browser which can run on an LCD screen in an office and rotate round screens showing current call stats, its been a winner for call centres. the second module is the scheduled email reporting section.
once I develop the third module I will consider putting the first module out to the community for free but at the moment I am charging clients for the software so it wouldnt be appropriate.
cost about 1200 AUD to develop but I am very happy with it, and have nearly covered costs.
module 3 will include secure access and some kind of visual display and record of where has been called and totals.
yarusemiKK
