Recording Quota
Benjamin Williams
I am looking for the Max Value that you can enter for the Auto Cleaning Options.'
My customer would like to save 3yrs worth of call recordings. I have entered 1,095 as my value for any calls older than 'X' value. The system does not seem to balk at this and I am able to save the changes without issue. However, I wanted to check w/the team first to see if this is going to really work or not?
See screenshot below. Can I safely use 1095 without concern?
PS - the 3CX server has plenty of space, I already have around 5yrs worth of calls saved... This is on a Windows 3CX instance. (v18 Build 20)
As @kieferschild mentioned this is the maximum value that the PBX will allow.
Reactions: Benjamin Williams
Excellent, thank you for pointing this out. Appreciate it!
You are welcome ;)
Senergia
