Redialing not working on Android client
inknow
When trying to redial it says a recording with number error, this because its cutting from the number the outside calling digit accroding to the outbound dialing
When re-dialing, the Android client redials exactly whatever it previously dialed.
Can you give me an example number? What number do you first dial, then re-dial?
Sure, for exaple according to my outbound dialing rules i should dias 9 + number; so i dial 9+ 5050505, it was busy, so i wait for some minutes, and then try to redial, on the registered dialed numbers on my android phone, it is registered only 5050505, so i order to redial it, and since there is no 9 on this number it takes me to the PBX messages saying wrong number, so i have to dial the whole number including 9. On my outbuond dialing rules i have a rule defining 9 as outbound and saying to cut the number for the PSTN
@inknow
You're performing redialing from Android's Call History (ie, Recents)?
Mahlon
