Solved Remove phone number in front of name in caller ID
Chrischevy80
When someone who is present in the contact list calls in, the phone (Yealink) diplays the caller ID in the following format (on 2 lines)
9991234567:Second Name, First Name
9991234567
The first line should be Second Name, First Name without any numbers in front of it.
The way it is now, the phone number is shown twice (1st and 2nd line)
Is there a way to remove the phone number that prepends the name ?
Not too sure if I'm being clear here...
Does this happen only on Yealink sets? What is being sent by your provider, only one number? I have seen some that send the number twice (once in the name field). I'm wondering if this has anything to do with it?
Reactions: Chrischevy80
Hello @Chrischevy80
What Yealink devices are you using and are the devices provisioned with the default 3CX template?
Usually Yealink devices once they match the number with a contact they will only display the contact as it is imported in the phone and will ignore what is being sent by the PBX.
I think you are right ! The cell phone number is sent both as the name and the phone number. Thanks!
Glad to see the issue has been resolved
Bluebox Global
