Removing "+" in Caller ID
DaleT
In both inbound and outbound calls the caller iD has the "+". I am trying to remove that.
I have read the following like and searched through the forum. I can't for the life of me figure out how to remove this.
https://www.3cx.com/community/threads/inbound-cid-reformat.59243/
I thought adding should work.
Source = +
Replace = /1
Can anyone throw a guy a bone?
Source = +
Replace = /1
That's what you're looking for. Adjust the pattern if you want to remove + or +1.
Are you sending the + on outbound calls (check the Activity Log), or is this being added by your provider, or perhaps by the provider at the far end.
Ok - I think this is solved.
The outbound caller ID appeard to be incorrect. Newbie issue.
[email protected].
