Solved Reporting questions
treboR
Forum User
Is there a dictionary that is available to download that describes all of the reports associated within 3CX?
Hi @treboR,
Partners have access to a document they could send you with regards to reports, which is a compressed summary outlining each report and what they do. You can contact a partner here.
Hi @treboR,
Vasilis,
Thanks for your prompt response. We currently have the 3CX Enterprise Perpetual 16.0.8.9 edition. I simply want to obtain the documentation of all reports and summary.
Hi @treboR,
I understand. The correct procedure would be to contact a 3CX partner and ask them for a copy, as they are entrusted with additional resources.
Hope this helps.
Yes, it helps out.
Have a Great Weekend also.
Reactions: VasilisV_3CX
Kayla Norris
