Restricting the sending of attachments
alex.filip
Question about restricting the transmission of files (attachments) in the mobile application, is there such a thing? Or if not, is it in the plan? It is also possible to restrict the sending/receiving of attachments outside the organization. For example, it should be possible to transmit only internally.
Also another question, there is such a parameter: CHAT_INVALID_FILE_EXTS in which it is possible to restrict according to the file extension, but there is no option to completely block the transmission. For example - it is possible to send a file without an extension or with a composed extension. Maybe there are some hidden parameters that can give the opportunity to restrict more settings?
Thank you!
Please note that the chat requires valid extensions. Also it is not possible to restrict the the file sent from the chat.
Finatra.us
