Resume call after rejected unattended transfer
freetreex
Platinum Partner
I was reading a forum that was having the same problem, said this might be added on v16 which was "in alpha" at the time 2ish years ago.
" We've been playing with the softphone on the webclient and we seem to have found a snag:
Caller rings A and ask's to speak to X.
A uses Attended Transfer to speak to X, caller is now on hold.
X declines to speak to caller, A ends call with X.
Caller is still on hold and A only has options of Transfer, Attended Transfer, Conference, Record or End. There doesn't seem to be any option on the pop up window to return to the caller?"
I still cannont seem to find this feature. 3cx is in v18 now, has it been added and if so how would one access it?
Thank you
Reactions: wade8421
Hi @freetreex
What PBX version are you running? Are you using the Webclient to control an IP phone or is it standalone? To answer your question a "Resume" button exists now on the Webclient which enables you to get the call back.
gmacinit
