Solved Revert back v16 to v15.5 on Debian 9
jorgemichel
Is it possible to go back from version 16 to 15 on 3cx phone
Do you mean you want to go back to version 15.5 ?
You have a few issues to overcome
  1. Your license key will not work , as it has been upgraded. I believe ver 15.5 keys are not available.
  2. Only possible if you have a ver 15.5 backup , backup created with 16.0 will not work.
  3. If you use any of the mobile apps, these will not be supported.
Why do you want to go back ?
@Saqqara my management console is not opening
@Saqqara
I've done the reboot
the OS is debian
The Management Console Service
But when I restart the Management Console service I get this error:
Unit 3CX.service could not be found.
Unit PhoneSystem.service could not be found.
Unit Management.service could not be found.
Unit Console.service could not be found.
Did version 16 work ?,
Did it failed after the upgrade. ?
How did you do the upgrade, if you where ?
Do you have a backup of ver 15.5 or 16 ? If so you could try installing 3CX - https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
I am not familiar with Debian , hopefully someone else will be able to help you
Did you upgrade to V16 from a previous version? Did V16 worked after the update? What Debian version are you running?
It looks like you have a corrupted installation so if you have a backup the fastest way to recover is to re-install the PBX. Make sure you are running Debian 9 and that the system has been uninstalled correctly.
You could also re-install the OS from the 3CX iso. https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
Thank you very much for helping the problem solved if with the new installation and backup restoration.
Reactions: AWS2P
Kayla Norris
