mcaponong Silver Partner Advanced Certified Joined Oct 29, 2018 Messages 107 Reaction score 43 Dec 30, 2019 #1 Is there a way to revoke a mobile app form accessing the system? Does changing the sip id and password revoke it?
SweetAction 3CX MVP Gold Partner Joined Jan 19, 2018 Messages 3,465 Reaction score 2,324 Dec 30, 2019 #2 force tunnel and then block tunnel on that extension. sip id/password will not block it, as it reprovisions with the new ID automatically. 3CX recommends remove and re-create the extension if the end user is being let go.
mcaponong Silver Partner Advanced Certified Joined Oct 29, 2018 Messages 107 Reaction score 43 Dec 30, 2019 #3 thanks
nb Support Team Joined Jun 7, 2007 Messages 2,510 Reaction score 392 Jan 16, 2020 #4 Del;ete extension, reset password from phones page, block extension Check the phones page and the extension tabs - You will find what you need in there. (of the management console)
