Revoke active connection
etelecom
Platinum Partner
is there any time line to revoke active connection ? or some inactivity timer to get user auto revoked ?
i observed that 3-4 month old connections are still active wiht old dates, and new active connection entry for same user also appearing in admin
In the Active Connections panel you can select to view expired - that will give you an indication of the session expiry time with regards to the PBX itself.
is there any timer setting available to set , so user's session will be auto expire after some time ( may be 1 day or 7 days etc ) ?
i have observed so many active session from same user and same IP address . it is referring to user's past login
As the team is on the Christmas brake, if you remind me after the 5th, I'll check - you could open a ticket if you wish, support team might know something along those lines, but I don't have an immediate sugestion.
tom.walker@blackcountryra
