Route all 3CX traffic to specific WAN
CBUTLER
I currently have 3CX on a server behind multiple WAN connections (Sophos XG). If I force all connections from that server to WAN2, 3CX works fine. It I try to forward only specific traffic then 3CX has no audio and cannot connect calls. I used the following ports: TCP/UDP 5001, 5060, 5090, 9000-9500, 7000-7500.
Is there anything else I'm missing that needs to be forwarded. I don't see anything else listed in the 3CX documentation but apparently something isn't being forwarded which is causing the audio to go through WAN1 instead of WAN2.
Just a quick idea.
I understand the SBC uses just one port?
Maybe you can install an SBC in the lan, point extensions there, then route with a simpler rule traffic from the SBC via one WAN?
hope it helps
