Routing calls between 2 trunks configured in 3CX
jawadaliqamar
Trial User
I have 2 Generic SIP trunks configured in 3CX.
1. First SIP trunk is with CUCM IP (Simulated PSTN).
2. Second SIP Trunk is with a third-party PBX.
3. Both CUCM and third-party PBX have SIP Trunks configured to 3CX.
I want to achieve the following with 3CX.
a. When the call is dialed to first CUCM SIP trunk, Main trunk number, it should route to the Second SIP trunk.
b. When the call is dialed from the Second SIP trunk, it should go out using the first SIP trunk (CUCM IP).
How can I achieve this?
Hey, can anyone please assist on the above topology?
Is this topology supported in 3CX?
No it's not supported. You should use a different switch software like Freeswitch or Asterisk and code the whole thing yourself.
3CX is not meant to be used like this.
Reactions: SweetAction
Finatra.us
