Salesforce Phone Result
mohan.vineeth1988
New User
I had integrated Salesforce with 3cx. I had added test contact in salesforce with Mobile number which is a 10 digit number and a phone number with 9 digits. When i query from 3cx I get the results for mobile number but not for the phone number. If I add a 10 digit number to field phone number i can still receive the results. With 9 digits this is what I am receiving "CRM Integration is working OK but contact number does not exist. Check log for more info or try a different number."
Please check this:
https://www.3cx.com/community/threads/3cx-salesforce-integration-configuration.82314/#post-381906
Salesforce will automatically reformat some numbers depending on your location and the number length, so the best way to ensure that the integration works is:
1) Store numbers in Salesforce with E164 format, that is the plus (+) prefix, country code and local number.
2) Configure 3CX to get the number from the SIP Trunk in E164 format.
That way contacts should be matched without problems.
Stephan Eusebe
