Salesforce V2 Authorization
abhishek.kumar.prna
New User
While authorizing SalesforceV2 it is getting redirected to https://login.salesforce.com/services/oauth2/token (production org). I want to authorize my Sandbox org, I checked the template but cannot edit the Sandbox url. Attaching the snapshot of the template. Can anyone help me on this so that I can authorize my sandbox and start testing.
You will need to edit the template to point to the sandbox URL. This is not something you can control with a parameter, so the only way is editing the template, and uploading it again with a different name, to avoid overriding the standard template we provide.
Hi Ernesto,
Can you please guide me with the steps how to create custom template and assign that to Salesforce V2?
Basically:
1) Get the template from your installation (3CX Console > Settings > CRM > SalesforceV2 > Show Template), and copy it to a text file.
2) Change the "Name" attribute in the second line to "SalesforceCustom".
3) Make the changes to the template (replace the endpoint login.salesforce.com with test.salesforce.com)
4) Save the file as "SalesforceCustom.xml".
5) Upload the file to the 3CX Console > Settings > CRM > Add.
Reactions: TheodorosG_3CX
Hi Edossantos,
Thanks a lot! I've created custom template and authorized Sandbox environment.
