Samsung Phones an Telecom API
nobody
It looks like nearly any samsung phone cannot use the Telecom API. But Samsung is the #1 Android phone manufacturer.
I personally do not need the integration for Bluetooth/Car, but if one of 3 phones are Samsung it seems it would be a good thing if this works also for a Samsung phone.
Samsung phones work with Cars. Shouldnt it possible to get 3CX Telecom API working with Samsung?
If Telecom API is not supported by the device itself I'm afraid there's nothing that can be done from the 3CX side. This however does not mean that it will not work. Have you already tested a Samsung device with 3CX installed using bluetooth/car and had issues?
I have only an older Samsung phone, and my car has no BT. But It would be great to hear that one can use a Samsung phone and use it with his Car together with 3CX (including phone numbers possibly).
I really dont care if Samsung is compatible with a special API or not if not 30% of all Phone users are unable to pair their Phone with their car and use the car as a speakerphone with 3CX.
Can someone confirm this?
Stephan Eusebe
