Satisfaction Survey
howar
Hello!
I have a question regarding Satisfaction Survey
lets say I want to make at the end of the call of queue voice "Satisfaction Survey" for customer to let them press 1 if they are happy,
2 not bad,3 bad service.
how could I collect the data and report for caller customer number and extension of the agent serve that call
is that possible ?
Thank you
You can create a CFD app using the Survey component to do this. Your agents will need to manually transfer the call to this CFD app when they finish speaking with the customer. The Survey component will write the results to a CSV file in the 3CX server, then you will need to get this file and analyze it yourself.
Thank you for explanation!
Have a nice day
Reactions: edossantos
As @edossantos correctly mentioned, you can build a survey using the Call Flow Designer (CFD) and assign an extension number to this survey. What has not been discussed is how to get callers to the survey.
In a perfect world, when an agent hangs up, the phone system would automatically transfer the caller to the survey. Unfortunately, this is not possible. Once either participant in the phone call hangs up, the call is gone and no further action can be taken. This therefore, necessitates that the agent transfer the call to the survey extension before hanging up.
Unfortunately, while it is straightforward to transfer the call to the survey extension, this approach has one significant flaw. What if, for example, the agent had a fairly unpleasant conversation with the caller? Do you think it is likely that the agent is going to transfer the caller to a satisfaction survey knowing full well that the agent is going to get a bad review? There is obviously a big disincentive for the agent to transfer some calls. Having the agent selectively transfer positive phone calls to the survey will naturally result in a significant leaning toward positive reviews.
So, what is the alternative? I would propose that you call every customer back AFTER the phone call is finished. But how can you automate that process? You could direct all inbound calls to a separate CFD application that asks the caller if they would participate in a post-call survey. If they agree, you could then confirm their call back number, write that number to a database, then forward the caller to the appropriate queue.
Once you have a list of people who have agreed to take the survey, you can use that list, along with a CFD dialer, to call back the people and send them to the survey.
If this sounds like a lot of work, it is. However, we have a tool that combines all these requirements into one solution. 3CX Survey Creator will ask callers if they are willing to take a post-call survey, collect/confirm the call back number, then immediately call the person back as soon as the original call is disconnected, and finally transfer the caller to your survey. Even better, we know who the agent was that took the original call, so we can associate survey results with a specific caller and agent. With this information you can now identify which agents are knowledgeable, courteous, and helpful, and who are not.
Reactions: howar
Thank you for your reply and explanation @VoIPTools
I think it's better at the end of the call(hang up) automatically transfers to a satisfaction survey.
I would like to confirm if the CSV file includes the caller number, queue number, and extension number (agent) who answered that call, and evaluated gives to an extension(agent) if 1-2-3-4 on that way.
and the supervisor can collect that data easily?
Either I have misunderstood your most recent post, or you have misunderstood mine. If EITHER party (the agent or the customer) hangs up, the call is gone and you cannot get the caller to the survey. You only have two options: (1) the agent transfers the call to the survey, or (2) you call the customer back. It is possible to automate the call back, but there is no way to automatically transfer the caller to the survey -- period.
Hello Dears,
Where can i find this path on 3cx console surveydemo/results/results.csv ?
Best regards
That's not accessible from the 3CX console. You will need to access your server via FTP or SSH and get your files.
Can you place here the location please?
Best regards
Best regards
According to the documentation here:
ExportToCSVFile: The relative or full path to the file for saving the results. The value is an expression. If a relative path is provided, results are written in this folder:
  • Windows:
    C:\ProgramData\3CX\Instance1\Data\Callflows\Surveys\project
  • Linux:
    /var/lib/3cxpbx/Instance1/Data/Callflows/Surveys/project
The logs in verbose mode will tell you exactly to which file the results are being written to.
Actually, the CFD app might specify an absolute path and save the results in a totally different location..... In the 3CXCallFlow.log file in verbose mode you will see exactly what the app is doing.
There is another option that I should mention. You may want to take a look at our 3CX Survey Creator tool. This is a commercial, fully supported (by VoIPTools) add-on for 3CX. It makes creating an unlimited number of surveys pathetically simple, and the results are tabulated and presented for you with a simple web interface. You can ask yes or no questions, true or false, on a 5 star scale, record their voice responses, and more. And, we handle the automatic call back option too. If you do not want to hassle reverse-engineering someone else's solution and want 24/7 support, maybe we have a better solution for your customer.
LeeonLau
